Unread 03-27-11, 10:54 PM
The photo is when flying in the Twin Comanche several weeks ago. I have a Ram iPhone mount that I bought from Amazon for about $20 and it works great. Holds well and that is important while flying in some rough air. The Ram mounts just work best.
This photo shows the bearing to the destination in magenta line. It is pretty accurate although does not react or update the altitude and speed as quick as Foreflight. The gyro action is good but must be calibrated in level flight first and then if you change to another app or function when you come back to BB Flight you have to acknowledge the disclaimer and re-calibrate again. Might be distracting in IMC to have to do this.
Name:	iPhone horizon.PNG
