These numbers come from my spread sheet off my computer. The spread sheet simply totals the categories for each month and I can read the totals in any category for the month or year. The "airplane" category had these numbers I posted for the past three years. My data prior to that included operating multiple airplanes under the one "airplane" category so 2006 and earlier was more than just the Skymaster so I do not have easy access to the totals for just the Skymaster prior to 2007. Since 2007, I have been operating only the Skymaster.
As for what causes the variations in operating costs from year to year is simply that some things cost more to fix or replace then others. I could go back to my files and dig out invoices to see exactly what went where but that will take too long. What I can do is recall from memory some examples of things that have either been fixed or replaced over the years since 2002 and the approximate cost for these things to hopefully give you an idea of what can all be involved financially.
Each year the "base price" annual runs about $4500 gradually increasing from year to year. That is to say if my shop takes the plane apart and puts it back together and finds no discrepancies then the annual will be $4500. Anybody who has operated an airplane knows that this never happens. Something is always broken or should be replaced simply from a preventative standpoint. If I have an annual that does not turn up any major discrepancies then I will take advantage of that and spend money on something that should probably be replaced but did not necessarily have to be replaced. I mentioned in my last post that 2010 so far has been going well. If the annual in this coming November 2010 proves to be a relatively discrepancy free annual then next on my list are all new flight control cables.
In the past several years items that have been repaired or replaced and approximate cost including labor are as follows in no particular order:
1) flap cables - $2000 to $3000
2) props resealed twice and other prop parts (2002 and again in 2009) - $1500 to $2500/prop
3) both vacuum pumps - $500/pump
4) new prop governors - $2700/governor
5) rear muffler twice - 2003 and again in 2007 - $2000 to $2500 each occurance
6) motor mounts on both engines - cannot recall price
7) starters on both engines (internal gears failed) - $3500/engine
8) throttle, prop, mixture cables on both engines - cannot recall price
9) windshield - $2500
10) several interior plastic furnishings and interior parts - $4500
11) much autopilot repair and avionics repair over the years - several thousands
12) new encoder - $500
13) replaced signal conditioner and fuel gage issues - $2000
14) new brake discs will be installed this fall 2010 - not sure yet
15) rear prop removed and repaired due to F.O.D. - 2007 - $1500
16) replaced all hydraulic lines for the landing gear - cannot recall but expensive
17) several electrical issues, rewiring, battery cables, etc. (see my post on "over-voltage") - $2000
18) new auto-pilot attitude gyro - $2000
19) over-haul second attitude gyro - $500
20) replaced ELT with used serviceable unit - $150
21) many hrs & parts to get both the original Cessna CHT/EGT system and JPI CHT and EGT systems working - $$$
22) fuel leaks, lines, and senders repaired or replaced - $2000
23) aircraft trim system was completely out of rig and need to be redone - cannot recall
24) electric trim inop and rebuilt to function proprerly - $1500
25) replaced rear cowl-flap motor (front one getting slow but still working) - $2000
26) repaired cracks two or three times and repainted rear cowl (it took awhile for the shop to get it right) - $$$
27) repaired a fairly large crack in the belly skin behind front left exhaust pipe
28) replaced fuel caps
29) had enough yet?
Anyway, hopefully readers get the idea. As I have said before, the C337 is a wonderful flying machine. They are expensive as any twin engine airplane would be. People who are considering operating these airplanes need to understand that the costs are expensive and can vary widely. No two Skymasters are the same. Turbo and P-models will only add to the costs, ALOT. If you can live with the costs, I would recommend the airplane in a heart beat.
A $15,000 annual is routine for me. A $20,000 annual is not out of the question and I probably would not start to cry until the annual exceeded $25,000. My smallest annual was about $8500 and the highest was $20,000. The big one was the first one in 2002. Last year was around $15,000.
Just remember, the easy part is the purchase. The operating costs in short order will blow through the acquisition costs.
Hope this helps! This is simply my experience. Others may be different. I enjoy my airplane and am mostly happy to have it.
Ed
Ed
