The issue of power and extended endurance is precisely the question. These engines are not rated for extended operation at full (i.e., take-off) power. If your closest landing is 1 or 2 hours away, you want to go to full cruise power, which is the top of the green band or 25/25. I believe that the engines are designed to operate at this power for extended periods. Can we start with that? Do you all agree or disagree? Then, will it maintain 5,000 ft at 2/3 load on a warm day?
I think this aircraft -- and all twins -- are designed to do that. Am I wrong?
In a single-engine aircraft, you have to promptly find a landing spot if the engine quits. Are we saying that our second engine simply extends briefly (5 - 15 minutes) the time we have to pick a landing spot?
