337 Vstol Turbine
New life for old 337. The Groen RevCon 6G is based on a 337 fuse with a Rolls Royce 250 Turbine and a two-blade rotor system. The actual 337 fuse is 337-0181, which is a 1965 model originally registered as N2281X, then went to Canada as C-GQRZ, then back to USA as N28AT. Groen registered this 'unusual' aircraft as N9112A. A simple search on Groen RevCon 6G should provide photos and description. Just thought it is worth a look.
