Thread: Center Console
Unread 05-01-10, 06:21 PM
Are my seats and rail set right
Jeff,
I received the center console and tried it in my aircraft. Thank you. I've included some pictures. It fits perfectly between the back seats, but there is no way it will fit between the front seats (even if I remove the seat covers).
Herb,
There are two levers on each side of my seat. The ones inside are the levers that allow the seat to tilt all the way back. The outside ones are the gear tooth ones that allow you to adjust the seat inclination. Are the gear tooth ones suppose to be on the inside? Are your seat rail holes suppose to be on the right side of left side? (mine are on the left side in the picture).
I'm suspecting my seats and rails are reversed.
Thanks for any help,
Karl
