Thread: Cessna C337 SID
Unread 04-05-10, 09:11 PM
Chances are that your plane is as safe now as it ever has been.
You don't need to do anything. The SID is optional, if your plane is used flying part 91, and you are not operating under an FAA approved maintenance program.
You just should be vigilant to normal deviations while performing your preflight inspection, such as skin wrinkles that weren't there before, smoking residue originating at rivets, and so forth.
