Unread 08-30-02, 02:37 PM
Bob Cook Bob Cook is offline
N69S
re fuel guages
Kevin / Joe
NOT that easy. These are capacitive guages and require a unique test box for calibrate the guages. There are not many around. Somewhere recently a SM owner replaced them with a newer alternative.
Most of the problems can be diagnosed to bad cables and connectors. try these first. check if it is one tank or both .
The systems differ greatly between p and earlier 337 or 336s. Number of tanks and if there are aux tanks. Need to start out by determining which type of aircraft.
Can of worms.. GMAS should be able to help
bob
