Tony's probably right
I had a 65 Skymaster s/n 0028. Same issue, could not turn the rear engine backward. Found it was the starter impulse coupling on the factory reman I installed. You might want to consider pre-oiling by pulling the plugs then running the starter motor with fuel at idle cut off until you get normal oil pressure. Reinstall the plugs and fire it up.
