Check valve help
I am having problems getting the corrrect part number for the front engine turbo oil return hose check valve.
My Cessna IPC notes it as being 3142-00 and have been told that the P/N goes to P/N S2360-1. Can someone please help.
The valve is a #8 male to male AN fitting on each end.
The IPC shows the same P/N on the rear turbo but that is wrong.
Thank You, Kevin
214-226-1504
