had gear problems, it was recommended that the hyd. pack be overhauled, so i did. it did not
make any difference. i'd spend the money on replacing all the hyd. hoses, maybe wheel well
wiring and the limit switches. after the hyd. pack overhaul had a gear failure a few months later. a pin hole in the middle of the nose gear hyd. line. no fluid gear stays in transit. if the
hyd pack takes a dump, you can hand pump it.
