Rough Airfield
If you take off from rough fields, it is best to get yourself rolling with the rear engine and bring in the front engine once you are moving, providing you have a long enough field to do that. On landing both engines are at idle, so that is not as bad. You still have the chance the tires will kick up stones and they always manage to find the rear prop. Good luck on rough fields. Dale Campbell
