Unread 04-07-09, 11:50 AM
N456TL
The routing of the hoses is the problem. You want the hoses positioned so down locks are held in the up position until the gear strikes them and causes them to start to swing. At that time the movement opens a valve and causes them to pressurize and lock down.
If the locks start to pressurize too early you will have problems.
Good luck.
