Unread 02-26-09, 04:28 PM
SteveG's Avatar
SteveG SteveG is offline
I installed the Rosen visors several years ago and experienced similar difficulties. As I recall the stiffeners were not even close to the proper size, shape or form requiring a couple of hours of grinding, bending, trial fit and repeat until I had a servicable arrangement. I found the visors to be an effective sun block but found their two claims to fame, transparency and adjustability, more hype than substance. You wouldn't want to bet your life on spotting conflicting traffic while trying to see through them and although they are somewhat adjustable the sun is somehow always just out of their range. On the wingtip installation; I assume you or your mechanic have strap duplicators but if not they are a slick little tool for match drilling the new tips to the existing nut plates that you definitely want to employ.
