  #92
Unread 02-17-09, 10:12 PM
Attached is a word file that has all 4 paint scheme versions on it. once you open the file zoom in to about 200% for good detail. Also looking at them at 100% would be about what one would see if the aircraft was on the runway taking off while you stood on the ramp. It is a good contrast to look at the designs that way.
Scheme 4 has been changed to provide an extra color stripe, Maya Gold and also the design on the vertical stab. Scheme 3 has taken the original belly colors and stretched them out to give a longer fuselage look. I think it worked on scheme 3. The template also is a non-pressurized cabin to provide the correct window configuration.
With scheme 3, would the all white cowling cause glare in the pilots eyes? I know that some of the pictures of Skymasters I found had all white (or what appeared to be all white) cowlings. Do they use a different sheen up there?
