  #32
Unread 01-02-09, 10:49 AM
Here are some more photos of the BAS seat restraint system. Attaching the two brackets together provides the mounting for the shoulder belt reel. One more attachment through the roof is actually an access hole to tighten the bolts inside the spar and then the hole is plugged with a stainless fastener. BAS drawing provides a clear picture of the process for the brackets. Last picture is the fuel tank inspection on the right wing. Five photos is max per post.
Name:	2JF BAS tech sht.jpg
ID:	723   Click image for larger version
Name:	2JF BAS Sys brct fin.jpg
ID:	724   Click image for larger version
Name:	2JF BAS Sys brkt fins.jpg
ID:	725   Click image for larger version
Name:	2JF BAS Sys 3 blt roof.jpg
ID:	726   Click image for larger version
Name:	2JF Strb tank.jpg
