Time sure goes by verrryyyy slooooowwww when your plane is in the shop. I do get pictures from the shop on a semi-regular basis, showing the progress that's been made. The aluminum left panel has been cut and the new radio rack has been installed. Now the panel has to go to the shop that will be powder coating it (grey). In the meanwhile a new breaker panel was also cut to house the new avionics breakers, and this panel will go to a shop in the States that makes electroluminescent panels, so one can actually read the different breakers' assignments.
Tic toc tic toc...
To the Blue Room!!
Jakes Dekker
