Unread 11-10-08, 07:49 PM
gkey's Avatar
gkey gkey is offline
This is a picture of the panel structure. Most of the braces and brackets are either corroded or broken. Also, the previous install did not go too well, and they had to cut away some of the supporting structure to make the centre stack fit (a big no-no!).
My mechanic did not want to remove and rebuild the panel structure, as this would imply tampering with the airframe structure. Instead, he found a "radio rack" with a STC specifically for Skymasters that can be installed without tampering with the existing structure. The beauty is that it will not only correct things, but also make the panel sturdier than ever before.
To the Blue Room!!
Jakes Dekker
