gear
thanks pete,
gear works fine on the down cycle and the gear doors close ok, only in flight in the gear up cycle the gear doors close and then they drop open. we use a mule with the plane on the jacks and everything works fine. I am not sure but I think the nose gear door stays closed
and work normal all the time!!!
gear handle does not come back to neutural only in flight and in the gear up mode, the rest of the time it works normal. keep in mind that i have dual hyd pump and the system works fast and does not drag at all.
