I just bought the switch from Yingling for $30, they had it in stock. There are actually four terminals to this switch, and the actuator button is in the center, which makes this unique. Two of the terminals are wired together so this makes this a single pole, double throw microswitch.
Take the white plastic drain tray off from under the powerpack, and you will see it towards your instrument panel. There are three wires going to a terminal board on the bottom of the powerpack, so you can take the switch and wires off as a unit.
