336 Crash
Robert Rice and Ernie Martin, if the probable cause was the failure of flap cables, that needs to be determined. Robert could you remove the failed cables and quadrant/bell crank assemblies so that they could be examined? Cable part numbers are: 1460100-7 (Inboard) and 1460100-8 (Outboard), 1460100-6 (Return) and 1460100-34 (Return). Quadrant/Bellcrank part numbers are: 142620-11 and -12 (Inboard) and 1426020-1 and -2 (Outboard). see Figure 83. in the Cessna 336 Parts Catalog. The cable part numbers that are single or double numbers after the dash are ordinay steel/iron cables. If the part number is a -3XX after the dash it is a stainless steel cable. I will be glad to help in the investigation.
Don Nieser, Commodore Aerospace Corp. 405-503-4686
