Unread 07-01-08, 11:11 AM
Larry, if you are in Heading or Nav mode the DG still provides Heading as this is required for crosswind correction whilst on a radial or a Loc approach.
Unfortunately this is one of the older autopilots that require the whole system to be there to make it work correctly, and with upgrading the autopilot there is no way around this problem.
Cheers
Pete
