Unread 06-19-08, 05:53 AM
Where did you get the flight track data? Is it from a web site? If so, what is that web site and will it work for any flight within the USA?
I find it very interesting that the last few minutes of flight were erratic in altitude and speed. It doesn't look large enough to be a T-storm, but it certainly might show trouble with aircraft control...VFR in IMC conditions, etc.
http://www.flightaware.com
It allows you to track any IFR flight, and gives the option of seeing the kind of data you see above. Just enter the complete tail number, e.g. N37KC.
It feeds live from ATC, so you can track a flight in progress, and you can also track all flights by a kind of aircraft, C337.
It only tracks IFR flights, not VFR, even those on a VFR flight plan, or flying with flight following.
