Electric/Manual Pitch Trim System O-2
I have a question regarding the trim system for anyone with O2 experience. Should the pitch trim both electric as well as manual as full travel as it relates to different flap setting (full vs. up/down, etc)? It seems my does not allow full travel outside of the takeoff/landing setting, as it relates to electric trim travel as well as manual.
I know there is a limiting function as it relates to flap setting, but it seems you should be able to run the trim both manually as well as electrically in the full range regardless of suggested trim limit?
Also, during annual both flap tubes were replace because of a improper screw that marked the tubes, to the best of my memory I didn't have this issue before annual......
If anyone has an O2 and can select the first setting of flaps, can you tell me if your electric as well as manual trim can travel both full range limits (up/down trim)?
Thanks, T
