I think you've covered all the bases and the only point I would make is that you shouldn't be overly concerned. Specifically, don't let this mystery keep you from using and enjoying your aircraft. You know that as long as you have fluid in the system, you can always put the gear down with the hand pump. It's a reliable, rugged system. I understand if you're frustrated but don't let it affect your aircraft use.
