You need a capacitance test set that plugs into the plugs on the signal conditioners in the roof and you will be able to check the capacitance of the sensors against the service manual. Cessna did a test set complete with all the leads and connectors for all the Cessna range, Bendix also did one. It is the only way you can troubleshoot the capacitance fuel system and calibrate it.
Cheers
Pete
