Hello John
The original KX175 are 12v and have a KA39 converter mounted somewhere behind the panel. The MX170B use the same unit. It is quite a big unit it is black, mounted with screws either end with six wires from it, that is either end as well.
There will be 2 as the systems should be separate for safety.
Should not take much finding, must be behind the instrument panel somewhere.
Pete
If you take the cover of the KA39 off the connection are marked so that you can check the 28v in and the 12v out.
