I have them and, in my case the engine isn't running any cooler. You have to consider, though, that I also added the air conditioner at the same time. I think that significantly reduced the airflow through the intake scoop. (The air conditioner condenser coil is located in the scoop.)
My typical parameters:
CHT: Front 260 deg f - Rear 320 deg f
Oil Temp: Front 175 deg f - Rear 220 deg f
Oil Press: Front 55 PSI - Rear 35 PSI
