Unread 08-25-07, 10:37 PM
Check your POH for procedure. Lead with the rear to be sure it is operating. There have been documented cases where pilots have just assumed that the rear is running and it was not. You don't have to use full throttle on the rear to know that you have it just lead with it to start and then follow with the front together.
