Elevator Trim Tab
No, nothing has been replaced. Cable tensions are good. The stop blocks on the cables are not the problem. Push rod in the jack screw has been adjusted in and out but that just reverses the problem from not enough nose up to not enough nose down. I suspect there is a problem in the manual trim wheel in the cockpit as the indicator wire will not go all the way to the bottom of the race and seems to go slightly higher than it should when rolled to full nose down.
