Unread 07-11-07, 12:55 AM
At least one thing I learned from this experience -- besides the fact that just because your nose gear works, doesn't mean something inside isn't broke (like the internal lock, or the plastic rod that connects the downlock hook). That is: if you ever want an easy way to drain your hydraulic reservior, just open up the nose gear actuator return line.
