Icing is always an interesting subject and I thought I would add my two cents worth.
I have had numerous trace and light events. Generally the ice disappears quickly after climbing or decending clear. I also actively avoid it and immediately demand to go lower or higher. In many respects I think it is very important to stress the urgency to ATC, as they seem complacent because of dealing with the big guys who don't have our issues.
I have the standard install, now with new boots that works pretty well. The only issues I have are that I have lost stall strips on several occasions when running the boots and the need to replace the exhaust solenoid on the front firewall. Both require some searching for decent prices. The stall strips are contact cemented on, but disappear during inflation, as there is no defined pad for them.
Shortly after getting the plane, I had a significant ice encounter with about 2" of rime and some clear on the leading edges when we landed. That was before I had working boots and strong motivation to get them working.
It was not nice with the whole plane rumbling and bucking a fair bit on the approach. By keep the speed up, things remained under control, and manageable. We were doing +100 knots over the number and touched down at pretty high speed. Fortunately I was with an instructor friend who had lots of time in 337's, but he was tense and most of the approach was flown at +120 knots.
BTW, it was a very localized event that happened very fast with neither the plane in front nor the one behind reporting much of anything. The joy of a bit of cumulus with good development and low freezing levels.
I have a suspicion that the aerodynamics on the C337's in icing conditions are not straight forward and that is one of the reasons Cessna did not go further forward. If I recall correctly, most of the rumble was through the controls and I suspect tail plane buffeting and stalls are the real challenge.
If anyone has additional experiences and/or knows of the results of the Cessna experiments, could they let us all know. We can all learn from the experience of others.
Blue skies - Dave
