Are you sure that its not a primer line? The manifold pressure usually doesn't run thru a "T" fitting. The manifold pressure line is in the center of the induction "Y" pipe, and the primers are one both of the elbow pipes.
Please verify that you're looking for the correct line, so that you're not disappointed later on.
